Sticky lifters and Marvel Mystery Oil
Posted: Mon Jul 03, 2006 5:29 pm
Hi All,
I'm not sure if this is the correct forum, but I will ask my question anyway; hopefully someone can answer it, or point me towards the correct forum to get suggestions and/or answers.
I own a 1987 Yamaha Virago 1100 (with only 20,000 original miles), it was garaged for a couple of years without being ridden. I had an oil change, tune-up, replaced front fork seals, cleaned and repared carborators, and had a new starter, etc. put in.
The bike now runs but the de-acceleration lifters are sticky and cause some sputtering and backfiring. The more I ride the bike the better it runs. My mechanic says just keep riding it; the lifters are sticky from non use.
It has been suggestedd to me to use Marvel Mystery Oil to help correct the "sticky" lifters, etc. Researching Marvel Mystery Oil on the internet has left me more confused than ever; some information leads me to believe that it can be harmful to the motorcycle (on many different levels), some that it is a waste of time and money, and others that swear it is the greatest product in the world and should be used regularly.
Has anyone had any experience with Marvel Mystery Oil and/or ever used it in a motorcycle with sticky lifters with any success?
If it is a good product for this application how much should be used? I have read to use as little as a teaspoon per tank of gas (the tank holds 4.4 US gallons) to as much as one ounce for every 2.5 gallons of gas.
What is the correct dosage one teaspoon in a tank of gas OR one once for each 2.5 gallons of gas in the tank? And after using the "treated" tank of gas do I need to change the oil again? (I heard that Mavel Mystery Oil can compromise the quality of the motor oil amoung other things, and that the oil should be changed after use).
Thanks in advance for all suggestions and answers.
