How do you keep track of what gear your in...
sharpmagna
#1 Unread post by sharpmagna »
I tried counting, but sometimes my mind is focused on something else and I forget what gear I'm in. I change gears by feel, so I sometimes forget to count too. It's fine if I'm in 6th and I need to downshift, but it is annoying when I'm in 6th and I think I'm only in 5th and I try to upshift.
I'm also getting proficient in telling what speed I'm going at a certain RPM and in what gear for whatever reason. It helped when my speedo cable broke (long story) and I didn't know how fast I was going. I could usually tell if I knew what gear I was in and what RPM if there were no cars around me that I could pace.
1987 Honda <B>SUPER</B> Magna
earwig
#2 Unread post by earwig »
I'm not sure about everyone, but once you ride your bike for a while you will just know by how it feels/sounds. If you are going to downshift more than 1 gear at a time and not sure what gear you are in make sure to let out the clutch very slowly so you don't lock up your rear wheel.
VermilionX
#3 Unread post by VermilionX »
when i forget... i do a quick check on my rpms and speed and i pretty much figure it out.
i have a gear indicator but it doesn't work anymore... TRE side effect.
jmillheiser
#4 Unread post by jmillheiser »
I usually have little problem telling what gear im in. Even though I cant hear the engine of my bike above 40mph.
if you really need to hear your engine to tell what gear your in I would suggest a louder exhaust.
m1a1dvr
#5 Unread post by m1a1dvr »
I cant hear my engine either at high speeds. So I feel the vibrations. I noticed that in higher RPMs it vibrates alot.
[img]http://i82.photobucket.com/albums/j270/m1a1dvr/dvrcopy.jpg[/img]
jmillheiser
#6 Unread post by jmillheiser »
mine doesn't vibrate much so I cant use that method LOL.
if im just cruising I know what gear im in by the speed im going.
if im in the canyons I usually dont know exactly what gear im in, I just use whatever gear keeps the bike at the low end of its powerband.
roscowgo
#7 Unread post by roscowgo »
The only time i really think about it is at a stoplight, when i make sure to click it all the way down.
Otherwise its like driving my truck to me, my feet and arms just do their things and i look where i wanna go. *does not work quite so well when you're swivelling your head trying to figure out where that squirell just went*
zed
#8 Unread post by zed »
I started with and still do the counting thing. At first, half the time I still forgot what gear I was in. After some time though I started to remember and now I seem to know what gear I'm in most of the time. I think it's a combination of counting and learning to correlate speed and engine sound.
I always follow the rules.
The only exception to the rule occurs when I make an exception to the rule not to make an exception to the rule and that only occurs under exceptional circumstances.
2005 Vulcan 500 LTD
icariz83
#9 Unread post by icariz83 »
Well on my SV I just know what range I'm in. If I'm going 30-45 I'm usually in 3rd but on the main roads of 55 I'm in 4th or 5th with 6th only for highways.
On the Triumph I just look down at the gear indicator, I haven't mastered the speed on it yet.
Current Toys:06 Daytona 675, 06 Sportsman 800
[img]http://i6.photobucket.com/albums/y249/Icariz83/misc%20pics/bronco1.gif[/img]
Kal
Real Name: Jade
#10 Unread post by Kal »
Kind of like Roscowgo I don't really care. I change up when the engine wants me to and down when I'm using the engine breaking. The only time I'm bothered by it is at lights or if I have pulled an 'urgent stop'. At those times I just bang the lever down several times and maybe up it up into neutral if I need reassurance.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
