Page 1 of 2
Signal lights? Can I go to larger bulbs?
Posted: Thu Jul 06, 2006 12:29 am
by Dragoon
I drive to work in the dark and because I need and have a fairing, I can not put a light bar on. Considering I drive 60 miles on the 5 in SoCal, I would like to figure a way to be better seen (I have the fluorescent stripes already). The thought occurred of increasing the size (wattage) of my signal bulbs. Has anybody done this?
I can’t imagine it would put strain on my electrical system compared to a light bar.
Any ideas techies?
Posted: Thu Jul 06, 2006 2:21 am
by CNF2002
Likely your blinker housings are designed for a certain watt bulb. More watt=more heat, might do long-term damage to the housing. Wire may be too thin to handle a larger current, will overheat could short it out. Fuse might not handle the current, may have to buy a bigger fuse.
Posted: Thu Jul 06, 2006 2:30 am
by Dragoon
all sounds reasonable to me.
Thanks
Posted: Thu Jul 06, 2006 2:34 am
by Big B
switch to led's if you can. much brighter, less draw and heat. should work out great
Posted: Thu Jul 06, 2006 2:46 am
by dieziege
LEDs aren't always much brighter... you must shop around and find LED lamps that are actually as bright as standard bulbs. However, when you find them they are a very good option because they draw less current and don't melt anything.
Posted: Thu Jul 06, 2006 4:35 am
by sharpmagna
Yup, LED lights are not always brighter than stock bulbs.
Have you switched to synthetic signal fluid?
Posted: Thu Jul 06, 2006 4:39 am
by earwig
Check out Shock Racing LEDs http://www.shockracing.com/products/ind ... r%20lights
Click the links on the left hand side... these are very bright.
by Sev
sharpmagna wrote:Yup, LED lights are not always brighter than stock bulbs.
Can you pick me up 2 pints of elbow grease please??
Posted: Thu Jul 06, 2006 5:10 am
by bok
my dealership sucks, they only ever have elbow grease in the left handed bottles
Posted: Thu Jul 06, 2006 8:23 am
by roscowgo
I ordered my headlight fluid from ebay.
