Page 1 of 2
VERY WEIRD Thing Happened.
Posted: Thu Jul 06, 2006 4:18 pm
by Dirtytoes
okay, so i'm on the freeway after about 30mins of riding.....going about 100mph high revs......and all of a sudden the neutral light starts blinking and a UN-steady pace.....then i freak out and pull over.
it goes off once i come to a stop.....then i exit freeway, ride for about 2 more minutes...make a left into my street and it turns back on.
only this time it's doesn't blink.....it just always on now...
what can it be? or what do you guys think it is?
Posted: Thu Jul 06, 2006 4:24 pm
by dieziege
An idiot light?
by ZooTech
Check the wiring near your shifter. Sounds like the neutral indicator came loose and is shorting to ground.
Posted: Thu Jul 06, 2006 4:48 pm
by jmillheiser
check the wiring near the neutral switch
Posted: Thu Jul 06, 2006 6:09 pm
by Randy
man, never seen that happen, and yes it sounds freaky.
Posted: Thu Jul 06, 2006 6:13 pm
by Shiv
Like they said it's probably just a short.
kk
Posted: Thu Jul 06, 2006 7:23 pm
by Dirtytoes
it's too dark out right now.....will check the wires tomorrow.
is it hard too find? if so, do i have to open anything to see it? reason i ask is that i've never seen any wires around the shifter.
i talked to my uncle and he said:
it might be your engine....the "neutral" light is the only light that the engine can use to warn you about something....get it checked out.."
...can that be true?
Re: kk
Posted: Thu Jul 06, 2006 9:38 pm
by TechTMW
No.
It's a short. When you ride a sustained speed/revs, (Especially, higher revs on an older sportbike ... where things get buzzy) the harmonic vibrations can cause stuff to vibrate loose. I don't know where the neutral switch is located on your bike, BUT your loose wire problem is most likely NOT in the engine/crankcase area. It's most likely in the headlight area or under the fuel tank, or even the wires in the console itself. You have to look at a wiring diagram to know for sure.
Re: kk
Posted: Thu Jul 06, 2006 10:32 pm
by Dirtytoes
No.
It's a short.
Thank God. will check it out tomorrow morning.
yaaa
Posted: Fri Jul 07, 2006 9:54 am
by Dirtytoes
i can't find it....i opened up a few screws on top of the shifter...and it only uncovered the front sprocket...where are the wires?
