Engine running funny
Posted: Sun Jul 09, 2006 10:11 am
Hey, I just thought I'd check here to see what you guys thought was likely the cause for something.
The other day after I took my bike to the car wash, it ran strangely for a while. I needed to prime the carbs (ie. ON/RES/PRI petcock setup) to start it even though I had just ridden it. Then at low RPM it sounded kind of clunky and if I let go of the throttle it would shut off.
This seemed to go away after a day or so, but obviously I wouldn't want this happening every time I take it to the wash. Was this probably caused by a few drops of water getting into the tank and I should check the seals in the gas cap area, or do you think it was something else?
Thanks for any advice!
