No Swingarm?????
Mr_Salad
No Swingarm?????
#1 Unread post by Mr_Salad »
I just got handed this flyer from a co-worker, advertising for the grand opening of this new custom cycle shop. The big show-off bike on the front doesn't appear to have a swingarm, AT ALL!!
So I ask her where the swing arm is and she replies, "There isn't one."
Anyone know how this works/if she knows what she is talking about? :laughing:
==1993 Yamaha XJ600S Seca II==
Mr_Salad
pic
#2 Unread post by Mr_Salad »
Here is a link to the shop's website:
http://www.midatlanticcustomcycles.com/home.htm
The "Swingarm-less" Chopper is the red one on the top.
Is it just a single swing arm on the other side? Or do they have something funny going on?
sharpmagna
#3 Unread post by sharpmagna »
Hey that's not too far from my house and it seems they're having a grand opening on the 15th. I'll have to check them out...
It does have a single sided swing arm from their website.
1987 Honda <B>SUPER</B> Magna
Mr_Salad
#4 Unread post by Mr_Salad »
Good deal.
Just trying to make sure that this little shop hasn't invented some insane electromagnetic/frictionless swingarm... :laughing:
Stratus311
#5 Unread post by Stratus311 »
Well without being able to see the other side with the swingarm, if there is no sprocket, then it is a Friction Drive. They basically use a knurled aluminum drum that spins on the wheel for forward motion.
[img]http://www.careercoders.com/images/Small-pictures/bike-sig.png[/img]
"Fighting for peace is like screwing for virginity."
“When you step on the brakes your life is in your foot's hands”
-George Carlin
CORSCO
#6 Unread post by CORSCO »
Stratus311 wrote:Well without being able to see the other side with the swingarm, if there is no sprocket, then it is a Friction Drive. They basically use a knurled aluminum drum that spins on the wheel for forward motion.
so what holds the wheel? :|
Stratus311
#7 Unread post by Stratus311 »
As long as it has a "swingarm" on the other side, it's basically a big bolt hub type thing that holds the wheel on. Basically just like a single sided swingarm on a Ducati or something.
EDIT: After going to Bourget's Bike Works website, I found out it's the Viper 2 and it's just a single sided swingarm.
-George Carlin
Mr_Salad
#8 Unread post by Mr_Salad »
That friction drive sounds pretty interesting. How does it get power to the drum? No sprocket, so there must not be a chain. Some weird shaft, maybe?
I asked around at work and all the guys seemed to agree that it was a single sided swingarm on the opposite side of the bike.
niterider
#9 Unread post by niterider »
It is very likely shaft driven.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
Stratus311
#10 Unread post by Stratus311 »
Basically it still has a chain but only to spin the drum. There is a special gearbox you use in order to spin the drum the reverse direction which spins the wheel in the forward direction.
-George Carlin
