1980 Honda CB750K Clutch Lever Replacement
Posted: Thu Jul 13, 2006 10:14 am
by BG
What's the trick to getting the clutch cable out of the lever? I've removed the pivot screw from the lever, and turned the adjusting screw, but can't figure how to get the cable loose enough to get it out of the slot in the lever. Any (and all) suggestions will be appreciated.
Posted: Thu Jul 13, 2006 11:03 am
by BG
I got it! I stuck a screwdriver into the screw hole in the lever, and squeezed the lever; this moved the pivot point far enough away from the perch that I was able to get a vice grip on the cable in order to hold the cable while I removed it from the lever.
