Tire Pressures Single vs two up
Posted: Sat Jul 15, 2006 4:11 am
I used to have a weight chart that listed Tire profiles - weight ratings and air pressures and for a certain gross vehicle weight of a bike.....
But alas...
Does anyone have these specs....?
I thought it was for every 50 lbs add 1 lbs of Air .....
Does this sound about right?
ex... 120/70 front 30 psi cold add 150 lbs passenger up psi to 33 psi
160/60 rear at 29 psi add 3 lbs to 32 psi (Tire pressures may seem low but it gets HOT here)
or is it just in the rear tire... ? Dam i hate getting old...
But alas...
