fork oil change/seal
Posted: Mon Jul 24, 2006 4:04 pm
Alright, this is going to make me look like an idiot, but I've already checked all the thread headings in this section and couldn't find the answer. I just bought a Honda CB 750k from 1982, and I also bought the Clymer Manual from bike bandit. The front suspension is washy, and one of the forks has a rim of oil popping out of it, which looks pretty ugly and I'm guessing is gross and contaminated. Actually, I know it's gross and contaminated, because I already drained it. I don't even want to think about changing the seals yet (though the new ones come in this week).
Now here's the problem, I undid the drain screws in accordance with the Clymer Manual (to see if an oil change was all that was needed to eliminate the problem), but then I got to the next part which told me to undo the top caps, problem is, my front fork isn't the one detailed in the manual, it must have been put on later. It has some sort of hydraulic system on top of the caps that links the two fork tubes together. I have no idea how to get it off. Should I just take the uppers out of the lowers and fill the oil in through the bottom fork? How do I even go about doing that? I've looked on the internet, and everyone seems to assume that I'm not an idiot and already know what I'm doing, but I don't, so if someone could enlighten me, I'd much appreciate it! Thanks!
p.s. My mechanical experience is limited to fixing lawnmowers and rototillers and some bicycle and car stuff. Motorcycles are a completely new adventure!
