suzuki gt750 front break master cylinder
Posted: Thu Jul 27, 2006 6:37 am
by mojocrankspleen
I can't get the master cylinder releace pressure, when I pull the break lever air is being pushed out of the break line, then when i releace the lever the air just gets sucked back in.
I took the plastic break fluid reserve off and cleaned both of the holes as best as i could, the hole on the right is cleared by the cylinder when the break lever is pushed in, but the left hole is always shut. are there two cylinders in breaking system (the second springing off the first) and one is stuck?
