Removing Baffles.
Posted: Sat Jul 29, 2006 1:33 pm
by Maleficent1
I have a set of Shogun Warlord cannons on my VT1100. I can see the baffles in there and it looks like they are just held in by allen bolts under each pipe. I removed the bolts and tried to remove the baffles to no avail. Does anyone have any tricks on how to remove them?
Posted: Sat Jul 29, 2006 1:41 pm
by VermilionX
Posted: Sat Jul 29, 2006 3:11 pm
by Loonette
Very cool demonstration...
Cheers,
Loonette
Posted: Sat Jul 29, 2006 4:42 pm
by ZooTech
That's the method of debaffling the stock pipes on the C50. Aftermarket pipes are debaffled by removing an allen screw.
Your baffles are probably just stuck. Try squirting some penetrating oil around the edges and let it sit over night.
Re: Removing Baffles.
Posted: Sun Jul 30, 2006 2:11 pm
by nyrblue35
Maleficent1 wrote:I have a set of Shogun Warlord cannons on my VT1100. I can see the baffles in there and it looks like they are just held in by allen bolts under each pipe. I removed the bolts and tried to remove the baffles to no avail. Does anyone have any tricks on how to remove them?
on my suzuki marauder i just had to twist the ends of the baffles with a crescent wrench then they came right out. they also had the bolt holding them in. but these were on cobra aftermarket pipes. hope that helps anyway.
