Disconnected hose, don't know where it came from
Posted: Sat Aug 05, 2006 12:49 pm
by skorman00
After getting a new battery and installing it, I noticed that there's a rubber hose that is connected to a metal line that comes out of the bottom of my gas tank. The hose is clamped to the frame on the other side of the battery, and goes down toward the transmission. The other end of the hose is not connected to anything. Where is he supposed to go? Is he supposed to be left open?
edit: Noticed there was a maintenance forum. Sorry for cross posting, but I'm going to post over there too. Feel free to close one of them, mods =)
Posted: Sat Aug 05, 2006 12:51 pm
by sharpmagna
It might be a breather for your tank?
Posted: Sat Aug 05, 2006 12:54 pm
by skorman00
That sounds likely. I'll turn her on and hope that I don't see gas flowing out....though now that I think of it, there should already be gas flowing if it were a gas line.
BTW I have a 2005 Harley Sportster 883C
Posted: Sat Aug 05, 2006 1:05 pm
by Sev
Bikes have a couple of hoses aimed out the bottem for overflows and things of the sort. I wouldn't worry about it to much, especially on a new bike. Is the end clean cut? Or does it look like it tore/broke off?
Posted: Sat Aug 05, 2006 1:12 pm
by skorman00
clean cut. I turned her on and checked, drove her around and checked again. I guess she's supposed to be there /phew
Posted: Sat Aug 05, 2006 2:36 pm
by KingRobb
most likely an overflow...I kinda freaked when i found mine on my Kaw too. But it was spewing gas when i found it cuz of some debris in the line.
Posted: Sun Aug 06, 2006 4:59 am
by polarelf2003
I agree, probably just an overflow in case you overfill your tank. My old Honda had 3 or 4 tubes underneath it, going to the tank, the carbs, etc.
On some bikes you'll see a small hole around the gas cap that is connected to that hose; itt'll keep gas from going all over your tank.
Posted: Sun Aug 06, 2006 5:19 am
by rapidblue
It's alot more noticeable on sport bikes when the fairnigs are off. Saw a gixxer yesterday with no fairings and there were 4 hoses just dangling.
So as said before no worries.
