Motorcycle tires. THey were bald to begin with
I am wondering if there is anyway to know if the tire you have is worn out. What tread depth should they be? I knwo on a car 3 or below means it is time to change it. Also car tires have wear bars. How do you know if your bike tire is done for?
- ofblong
- Real Name: Ben
Re: Motorcycle tires. THey were bald to begin with
must be some expensive tires that have wear bars on your car tires cause I sure dont have any. My car tire I use a penny and if I can see the top of good ol abrahams head then its time to change them. then again im in the us of a so its different for me than some of those on this board. either way id like to know the answer as well so im jumping on boardbobtasco wrote:I am wondering if there is anyway to know if the tire you have is worn out. What tread depth should they be? I knwo on a car 3 or below means it is time to change it. Also car tires have wear bars. How do you know if your bike tire is done for?
- VermilionX
- Years Riding: 6
- My Motorcycle: '06 Suzuki GSX-R 750
All DOT tires have treadwear indicators/wear bars. That's car, motorcycle... you name it, if the Dept. of Transportation regulates it the wear bars are there.
The trick is that motorcycles are allowed shallower tread depth legally. Cars need 1/16th of an inch, motorcycles only need 1/32 of an inch... so the wear bars are half as tall as you are used to seeing on your car.
Just look around the center of the tread, you'll find 'em.
- jmillheiser
- Nibblet99
In the UK, the law states for motorcycles you should have 1mm of tread, 3/4 of the way across the center of the tread pattern (the edges of the pattern don't count)
I hope that gives you some kind of guide, whether or not your own country has it's specific laws
