hi
i have a question mark in title as i am unsure. it feels like a fuel problem. any hints with the following would be appreciated
with the throttle open the engine starts cutting in and out untill eventually it stalls. was advised that under load i should run the fuel tap on 'prime' rather than 'on' to ensure valve does not close and starve carbs of fuel (which is apparently a common problem). did this and it still happened.
has been on the dyno and coils are fine
carbs have not been taken off and cleaned but rest of fuel system has
any ideas?
thanks
gs 500 fuel problem?
- Legendary
