Prevent fan from running after shut off.
I have a 2004 Susuki Katana 600 and would like to know how to prevent the fan from running after I shut off the bike? I am speculating that the fan runs after the bike is shut off for some emissions control reason (fuel fumes, etc), but it runs my battery down. Having a fan run after the bike shuts off really sucks.
- Z (fka Sweet Tooth)
No not the radiator fan..
No, there is another fan on the left side of the bike. In the farring there is a grilled hole were the air from that fan exits the bike. Again, I am thinking its purpose is for some sort of emissions control, but am not sure.
- ZooTech
- Years Riding: 18
Accelerating fuel fumes into the air via a fan does nothing to help the environment. The only fan your bike should have is the cooling fan which is supposed to run after shut-off to keep cooling the engine. It should not, however, run for very long - certainly not long enough to kill your battery. Either the thermostat is bad or your charging system needs attention.
- Skier
California emissions is met by having a fan cool down the carburator bowls after bike shutoff to slow down fuel vaporization (if I recall correctly). It doesn't evacuate the fuel into the air, it tries to slow or prevent it from occuring.ZooTech wrote:Accelerating fuel fumes into the air via a fan does nothing to help the environment. The only fan your bike should have is the cooling fan which is supposed to run after shut-off to keep cooling the engine. It should not, however, run for very long - certainly not long enough to kill your battery. Either the thermostat is bad or your charging system needs attention.
party_man: I suggest heading over to www.katriders.com and check out their extremely helpful forum.
