1st...CLUNK..wtf, neutral?!...2nd...
gitarjunky
#1 Unread post by gitarjunky »
Question, do any of you ever experience a 'clunkiness' when shifting? Sometimes when I'm shifting from 1st to 2nd, it seems kind of rough and sometimes I even get stuck in neutral, then have to shift again to get to 2nd. I notice it most when the bike is cold, is this normal? Is there anything I can do to get rid of the 'clunk'? I've driven stick my whole life so I like to believe that my gear shifting is smooth....any thougts would be appreciated, thanks!
phil
2005 Suzuki SV650
Get a yellow one....they're faster
m1a1dvr
#2 Unread post by m1a1dvr »
Just make sure that the clutch is all the way in and you pull hard and firmly on the shift lever.
[img]http://i82.photobucket.com/albums/j270/m1a1dvr/dvrcopy.jpg[/img]
VermilionX
Super Legendary 5000
#3 Unread post by VermilionX »
only happens sometimes to me when i shift to 2nd at 70-80mph.
i normally shift to 2nd around 40-50mph and experience no problem.
sharpmagna
#4 Unread post by sharpmagna »
If you're bike has a wet clutch then it is normal for you to notice when your bike is still cold. The engine oil is also the transmission oil so if your engine is cold, the shifting will be a bit harder until you oil warms up. My shift from 1 to 2 is clunky, but I've got a 20 year old bike so I don't pay it too much attention.
1987 Honda <B>SUPER</B> Magna
Randy
Real Name: Randy
My Motorcycle: 2007/Honda/CBR1000
#5 Unread post by Randy »
Yep, the crazy noises are half of the fun!
Trying is the first step towards failure - Homer Simpson
05 Yamaha VMAX
04 Suzuki SV650
05 Suzuki RMZ450
Randy
Real Name: Randy
#6 Unread post by Randy »
oh, and I did get a yellow one. You are right, they do go faster! :laughing:
05 Yamaha VMAX
04 Suzuki SV650
05 Suzuki RMZ450
rapidblue
#7 Unread post by rapidblue »
i'd be scared if my bike stopped making weird noises. :laughing:
80 honda CB750F Super Sport
Kal
Real Name: Jade
#8 Unread post by Kal »
Yeah mine is pretty clunky in first to second all the time. I've noticed that if I give it too many revs then it tends to spit the gear into neutral rather than second which leads to an embarressing noise as I crank the throttle open again before having to dump it back into first.
I just try to shift south of 8,000 rpm's now. Come to think of it I usually do this within a couple of minutes of leaving work in the mornings.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
m1a1dvr
#9 Unread post by m1a1dvr »
I have been having a problem with 5th to 6th. It will not go all the way into 6th. It makes a grinding sound and then it goes into gear. I dont know what causes it. I am pulling in the clutch all the way and giving a firm pull on the lever.
Kal
Real Name: Jade
#10 Unread post by Kal »
Only on 5th to 6th?
Kal...
