Scorpio Alarm
GQ
Scorpio Alarm
#1 Unread post by GQ »
Does anyone have a scorpio alarm? If so, does it work well? I've been told by some it can be easily cut so the alarm can't send you any signals.
http://scorpioalarms.com/sr-i500.aspx [/url]
zarakand
#2 Unread post by zarakand »
There was a review of it not too long ago. viewtopic.php?t=933
Itzamna
#3 Unread post by Itzamna »
Yep I have one and that link is to the review I did. It depends on what type of bike you have as to whether or not they can be cut easily. Some bikes have easier access to the subassembly than others. If they mean the antenna, you just have to place it somewhere unnoticed. You have tons of choices when placing it.
To be honest, the only way the could cut it fast enough, would be if they knew the alarm was on there beforehand, which pretty much means they know you personally. Otherwise, they'll most likely set it off before they even thought about cutting it.
Brian
'03 Suzuki SV1000
