xs400 Maxim Compression Issues
Posted: Thu Aug 10, 2006 3:26 pm
I'm sure most of you haven't followed my escapades as I'm just a newbie, but heres the quick rundown:
82 XS400J Maxim Motorcycle (yamaha). Thought it was an ignition issue that was keeping it from running. I had thought there was compression. So, today I replaced a blown diode, hooked up a brand new and charged battery, sprayed some ether in the carbs and tried to start her. Nothing.
So I think to myself, lets start from the beginning.
Check Spark, Yep, good and blue.
No Compression guage, but put my thumb over the hole. Hrm, odd, no pressure. Called the wife in.. Had her feel, still no pressure. Had her feel while turing the back wheel in gear, very faint. Put a ziptie down the hole and it moves when hitting hte starter/moving rear wheel in gear, so pistons are moving.
Check other side, some compression, but still very little.
So, its not an ignition problem, I just aint' got no compression. Before I start tearing into the engie, does anyone have any advice on what/where to check? I'm thinking rings, head gasket, valve adjustment.
Are there other options beside dropping the engine?
