Types of drives
flw
Types of drives
#1 Unread post by flw »
I've seen belt drives, shaft drives and chains on bikes both expensive and less. What are the pro's and con's of each please?
Goldwing 1500se '98
VN500 LTD '07 Sold
BLKNSLVR
#2 Unread post by BLKNSLVR »
I personally like shaft drive. Relatively maintenance free and smooth. One seems to find more lash with belts and chains. Both belts and chains take more maintenance (tightening, etc.).
Just my two cents.
Greg
www.openroadenterprises.com
jstark47
#3 Unread post by jstark47 »
Chain is the best combination of low weight, high durability, and efficient power transfer. But as BLKNSLVR pointed out, chains need tension adjustment, they also need cleaning and lubricating.
Mintbread
#4 Unread post by Mintbread »
Shaft drives are heavy. Which means when they are bolted to the rear end of a bike it is going to affect the abilities of the suspension.
Belt drives are an unknown for me but if they were that great they would be on a lot more bikes.
Chain drive is all I have ever used. They are used universally in racing so they must be as good as it gets.
