valve adjustment
Posted: Fri Aug 18, 2006 3:28 pm
by todostusmuertos
So I just got a V Star 1100 and I don't know when it was the last time they did a valve adjustment. How can you tell if you need one? I know you're supposed to get it done everytime you get your bike serviced like with an oil change and such.
The oil was changed before I bought it but I don't know about the valve adjustment. I just don't want to mess this thing up.
What will it happen if I just don't do it till next time I have it serviced? Is there a way to tell if the valves need to be adjusted?
Thank you
PS: I really dig this site and all the information in it. It sure makes things a lot easier for a lot of people.
Posted: Fri Aug 18, 2006 3:32 pm
by VermilionX
why don't you check your manual?
it tells there when it is time to check valves by mileage or years. mine says to inspect valves after 14,500 miles or 4 years.
the manual for your bike should have it too.
Posted: Fri Aug 18, 2006 3:57 pm
by BLKNSLVR
Valve adjustments are one of those things like "undercoating for a car". In other words, it is not something you can check unless you take the valve covers off and put a feeler gauge on it. After all that trouble, you might as well do it. The Crimson one is totally correct, I would follow the manual.
Greg
Re: valve adjustment
by ZooTech
todostusmuertos wrote:Is there a way to tell if the valves need to be adjusted?
Yeah, they'll make a bunch of racket!
Seriously, though, what's the current mileage?
Posted: Fri Aug 18, 2006 4:03 pm
by sharpmagna
Yup, RTFM. Some people don't believe in doing the valve adjustment check unless something is wrong (making lots of noises).
Personally I like my bike and want to keep it running as long as possible so I got it checked the when it was near 24k. Cost about $192 and next time I'll try to do it myself.
Posted: Fri Aug 18, 2006 4:06 pm
by BLKNSLVR
Touche' Zoo. I assumed that no noise was good news. :laughing:
Greg
Posted: Fri Aug 18, 2006 7:24 pm
by todostusmuertos
Wow, thanks for all the quick responses.
It is making a strange noise and I don't know if it's normal but its hard to describe. It seems like it's coming from the front near the tank.
The bike has 22 k miles. I better get the valves adjusted.
I wonder how hard it is to do cause I'd like to do it myself. I guess I can get it done professionaly the first time.
Posted: Sun Aug 20, 2006 12:55 pm
by oldschoolorange
BLKNSLVR wrote:The Crimson one is totally correct
WOW hey someone want to make this a sticky! :laughing:
You will hear ticking of your valves are really out of adjustment get a manual and follow it exactly and you should have no probs
Posted: Sun Aug 20, 2006 2:46 pm
by todostusmuertos
I checked the manual and it says to check and adjust valve clearance (assuming that's the valve adjustment) every 30 months after 20,000 miles.
I better get it done.
