removing JB weld from a gas tank?
Posted: Thu Aug 24, 2006 7:36 pm
by Lewy987
I recently got my hands on a 1982 Yamaha XS400RJ Seca. It is a beautiful bike for its size. Unfortunately it has a fuel leak in the tank.
I put JB weld on my tank to stop a leak on the bottom of my tank. It began to leak again recently and I want to remove the epoxy so I can weld it and reapply JB weld. I then want use POR-15.
any advice would be welcomed... thanks...
Posted: Fri Aug 25, 2006 2:51 am
by storysunfolding
... why would you weld it... and then reapply jb weld?
I can understand the POR treatment to get rid of corrosion and protect against future rust throughts... but JB weld is an epoxy that you use so you don't have to weld... welding is a much better solution
It's like saying "I need to fix it well, then fix it not so well"
Weld
Posted: Fri Aug 25, 2006 7:19 am
by Lewy987
I just dont want future leaks.
I'm gunna do everything possible to have this gas tank never leak again.
but thanks for the advice
Posted: Fri Aug 25, 2006 7:28 am
by storysunfolding
If you have it renued they already weld/por it for you.
Posted: Mon Aug 28, 2006 3:28 am
by MrShake
About the only way I can think of to remove JB weld is to cut it out. If its a big patch of JB, you might be better off looking for a new (used) tank. I see them on Ebay for the seca/maxim/special all the time
Posted: Fri Sep 08, 2006 1:08 am
by oldschoolorange
sandblasting/ bead blasting takes it off no prob, It worked for me
