chain drive, belt drive, shaft drive
stephen85858585
#1 Unread post by stephen85858585 »
What are the pros and cons of these different drive systems and ultimatley which is the best and worst
Depression Forum
Last edited by stephen85858585 on Mon Feb 23, 2009 12:58 pm, edited 1 time in total.
VermilionX
#2 Unread post by VermilionX »
check this thread...
viewtopic.php?t=16283
stephen85858585
#3 Unread post by stephen85858585 »
can anyone give me just a quick straight up answer? or is it really more complicated than that?
green crack photos
VermilionX
#4 Unread post by VermilionX »
stephen85858585 wrote:can anyone give me just a quick straight up answer? or is it really more complicated than that?
chain is the best... it's what race bikes use. :wink:
if you won't accept this answer then it is more complicated than that.
stephen85858585
#5 Unread post by stephen85858585 »
so if it`s the best why dont all bikes use chain drive then
resession
VermilionX
#6 Unread post by VermilionX »
stephen85858585 wrote:so if it`s the best why dont all bikes use chain drive then
like i edited... if you won't accept that answer then it is more complicated than that. :wink:
there's no just straight up answer.
Kal
Real Name: Jade
#7 Unread post by Kal »
It all depends on exactly what you want but....
It makes sod all difference. Seriously.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
t_bonee
#8 Unread post by t_bonee »
What he was getting at was there is another thread running at the exact same time running about the exact same question in a different forum on the board.
It doesn't matter, buy whatever bike you like, The final drive should not come into the equation. If you like the bike and it is comfortable for you, great. You will then deal with the maintenance of the final drive. If you love the bike then maintenance is a secondary issue.
A dog had his chain reduced one link at a time, every few days, until his chain was so short he could barely move. He never resisted because he was conditioned to the loss of his freedom slowly, over time. Are we in this country becoming like the dog?
flw
#9 Unread post by flw »
t_bonee wrote: It doesn't matter, buy whatever bike you like, The final drive should not come into the equation. If you like the bike and it is comfortable for you, great. You will then deal with the maintenance of the final drive. If you love the bike then maintenance is a secondary issue.
From reading this boards posts, it seems that most people are torn at the end before the buy of a bike. This is where it would make sense for things like options that are nice but not required, do make a difference in the end.
Goldwing 1500se '98
VN500 LTD '07 Sold
Lion_Lady
Real Name: Pam
Years Riding: 24
#10 Unread post by Lion_Lady »
Asking "Which drive is best?" Is kind of like asking "Which TIRES are best?" or "Which helmet is best?"
It all depends on what you want: What fits your needs.
Chain drive is probably the most common. Requires regular lubrication (~500 mile intervals).
Belt drive is similar to chain, but VERY little maintenance is needed (no 500 mile interval oiling, etc.): Just a periodic check for damage and tension adjustment.
Shaft is generally found on the larger displacement engines because they are heavy.
P
