Starter interlock prob...
dieziege
#1 Unread post by dieziege »
Had a mildly amusing one this morning.... I gear up and hop on my ninjette, ignition to on (oil light lights), pull the clutch, ignition kill off, hit the starter... nothing...
So went through the basics... kick stand position (down, but I flipped it up), gear (1st, but I switched it to neutral)... I flipped switches, turned the ignition off and on, still nothing.
Then I released the clutch lever and tried it... started right up.
So I shut it down and went through the same thing again... in neutral, ignition on, clutch in, holding the starter button I get nothing -- I release the clutch (while holding the starter) and "rerumumumum....." it's running.
Shrug.. I still needed to get to work, so I rode off on my merry way.
So now, after an hour+ ride, I'm at work. I park the bike (in gear), put the side stand down, then say "let's see if this works" and (holding the clutch) hit the starter... starts right up. I shut it down and try without holding the clutch... nothing.... so it is working normally again. :frusty:
So... any thoughts? Switch? Wiring? Something else? I don't want to tear everything apart looking for gremlins, but I also don't want to get stuck somewhere without any starter at all.
ZooTech
Years Riding: 18
#2 Unread post by ZooTech »
Start with the obvious and look over the wiring going to the clutch lever and the kick stand (if the latter is so equipped). I haven't had anything like that happen to me yet but that's where I'd start.
dieziege
#3 Unread post by dieziege »
blehg... can't make it fail again, can't find any obvious problem... I hate this sort of thing.
Oh well, back to pretending there is nothing wrong. :laughing:
Gadjet
Real Name: Owen Clark
Years Riding: 19
#4 Unread post by Gadjet »
you probably just got a bit of crud or corrosion starting to happen on the switch inside the clutch perch. I've had this happen to me on occasion, and my solution is to just pull the clutch lever in and then let it snap back out. Bike fires right up after that.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
