How tight should a chain be?
flw
#1 Unread post by flw »
Generally speaking, how much chain deflection should there be on the bottom part of the chain between the gears when pressing upwards?
Also is lubing a non-dirt bike chain once a year considered plenty?
Goldwing 1500se '98
VN500 LTD '07 Sold
fireguzzi
Real Name: Trevor
#2 Unread post by fireguzzi »
No, it should be lubed alot more
Mintbread
Re: How to tight should a chain be?
#3 Unread post by Mintbread »
flw wrote:Generally speaking, how much chain deflection should there be on the bottom part of the chain between the gears when pressing upwards?
~20-30mm
macktruckturner
#4 Unread post by macktruckturner »
I clean and lube mine at least twice a month. Currently slack level is to where I can just barely press the chain up into the plastic slider on the bottom of my swingarm.
noodlenoggin
#5 Unread post by noodlenoggin »
Put the bike on the centerstand or otherwise raise the rear wheel, then rotate it with your hand and you'll see that as the wheel goes around the chain has a "tight" spot and a "loose" spot. You should be able to move the chain about 3/4" at the "tight" spot after you get done adjusting it.
jstark47
#6 Unread post by jstark47 »
My manufacturers' owners manual gives a precise chain deflection spec for my bike. Have you checked yours?
flw
#7 Unread post by flw »
This bike is at a dealer and is not mine. I'm looking to buy it and wanted to see if the dealer really did anything in the "prep" of the bike.
The bike came with no manual.
Goldwing 1500se '98
VN500 LTD '07 Sold
2wheel
#8 Unread post by 2wheel »
Check the chain before each ride. Lube as required.
1999 VFR
2005 KTM 300EXC
2004 GS500F (girlfriends)
www.2wheelcentral.com
www.iboxcabinets.com
#9 Unread post by Sev »
About 3/4 to 1.5 inches depending on the bike. I believe that is under load. Meaning if it's 3/4 of an inch deflection while the back wheel is off the ground (to adjust) it'll probably be to tight once you sit on it, and the swingarm moves tightening the chain.
2wheel
#10 Unread post by 2wheel »
Some bikes have the numbers on a sticker on the chain guard.
1999 VFR
2005 KTM 300EXC
