I want to paint my fender, need help!
isnowbrd
#1 Unread post by isnowbrd »
I took the fender off my bike tonight, but ran into a problem. How am I supposed to get this metal piece off it?
Here is a picture of the underside.
I could just drill out the rivets, but then what should I do when I need to put it back on?
#2 Unread post by BuzZz »
Looks like you'll need a riviting tool, 3 rivits and 3 snug fitting washers for the underside.
You can buy a cheapass riviting tool, with a small supply of different sized rivits at most discount stores for 10-20 bucks. It will work well enough for most home-riviting you'll do.
isnowbrd
#3 Unread post by isnowbrd »
Thanks Buzz
It's been awhile sinced I've riveted anything (high-school). Aren't the cheap ones too small to be able to get at something in the middle of the fender like that? And don't they usually leave a protruding piece of metal on the underside which could damage the tire?
I don't understand how the existing ones are so flush.
Seca Girl
#4 Unread post by Seca Girl »
isnowbrd wrote:I don't understand how the existing ones are so flush.
Special tools used on an assembly line. Maybe even a robot.
Just drill them out and use some pan head machine screws to re-assemble. That way you won't lose any tire clearance.
Any home riviting you do will be inferior to bolting it on.
1982 Yamaha XJ650RJ Seca
oldschoolorange
#5 Unread post by oldschoolorange »
Just use decent quality rivets, If you go to a performance shop you can get them painted to match if you want, I have never had much luck with the small crappy rivet guns, I have allways used my big POP riviter ir an air riveter
83 GS550, 70 Yamaha CT1 175
Shorts
#6 Unread post by Shorts »
Yeah, don't skimp on the rivet gun. It'll be more of a hassel than if you spent a little extra. Be sure to get quality rivets too.
#7 Unread post by BuzZz »
I got a cheap gun from the dicount table at Acklands for $9.99. It is the same size and works about the same as the $99.99 Mason rivit gun I got at work. The only thing is it does not release the pulled expander pin when you finish a rivit. I have to dig them out fairly often. Works good enough for the 4-5 rivits I ever do at home. If I have more than that, I'll bring home the pneumatic gun from the shop. :wink:
If you have too much rivit shank left sticking out of the underside, your rivit is too long for the thickness of material your clamping together. Use shorter ones. And a close fitting washer will let the rivit seat well and strengthen the whole joint. If you still feel you have too much protruding under the fender, you can use a centerpunch to flatten it further, but you really shouldn't need to if you got the right sized stuff.
isnowbrd
#8 Unread post by isnowbrd »
Thanks for all the help guys. I went to the hardware store and found something called a Chicago screw that worked perfectly along with some threadlocker. Here are the results:
And here is my newly painted VTR. I still have to paint the wheels though.
moto_hanki
#9 Unread post by moto_hanki »
That looks so kick-"O Ring"!
Nice job!
Henri
1992 Seca II XJ600
oldschoolorange
#10 Unread post by oldschoolorange »
very nice, new paint is great isn't it
