Starting in 2nd?
Starting in 2nd?
My 550 is a bit of a dog in first gear. As a result, I often have to shift into second halfway through making a left turn from a stop. Should I just start in second to avoid the hassle of shifting mid-turn? From what I've read on here, it's basically impossible to mess up a motorcycle clutch, so why not? I've (accidentally) done it before, and the engine didn't seem like it was struggling.
- jmillheiser
To me half the fun of riding a bike is the use of the gears. I had a 454 ltd vulcan with 6 gear selections, I sure enjoyed going through all the gears. The only thing I see in not useing 1st gear is that you will not have a wear pattern from 1st to 2nd as the gears wear.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
one seater
horn relocation
- jonnythan
On sharp turns, like taking a turn at off a red light or stop sign, I'll just stay in first through the turn and shift up to second when I start straightening out. If it's a wide turn and I'm not leaning too hard, I have no issues with shifting mid-turn.
- TechTMW
- Years Riding: 10
Bingo!blues2cruise wrote: Usually the problem with starting in second is that the engine may lug.
If you are starting in second from a dead stop, you may be lugging your engine which will wear out pistons and rings and cylinders in a hurry. ARE you lugging your engine from a stop in second on YOUR bike? Dunno. But if you are, you need to use first gear.
- Lion_Lady
- Legendary 1500
- Real Name: Pam
- Years Riding: 24
Re: Starting in 2nd?
That this happens only in LEFT turns says to me there's something else going on. Heck, why not just 'wind it up' in first and shift up after you're straightned out.Rebel0007 wrote:My 550 is a bit of a dog in first gear. As a result, I often have to shift into second halfway through making a left turn from a stop. . .
P
