RozStar wrote:Good morning all! I'd love any advice y'all may have regarding batteries. I have a 1987 Yamaha Virago XV 535TC. The spec page says I need a 12 V/12 A/h. Went to Wal-mart last night to buy one and they sell something called ES 12 but it had some other alphabets (N E or something like that). Where can I buy a relatively cheap but good battery? The bike didn't have one in it when I bought it. Any suggestions are welcome. Thanks!
Hey that's the bike I have! In fact, I just replaced the battery too. I had a bad regulator/rectifier and ran the thing down to nothing one too many times.
I called around my local bike shops. One of them wanted about $70 for the battery, but another wanted $36, filled and charged. I wasn't able to find the battery at Wal-Mart.
The model you need is YB12AL-A2 or equivalent. This is an unsealed, low-maintenance battery, meaning it needs to be filled with acid and water before being used. The shop should do this for you. Initial charging can take a few hours.
While in use, it should be periodically checked for electrolyte level. The case of the battery is translucent and there are "min" and "max" lines on the outside. If the level is getting to the "min" line, you have to open six little screws on the top of the battery and fill it with distilled water. Check at every oil change.
Installing is pretty easy, but you may be confused by the clear plastic tube that comes with the battery. It's a battery vent tube. There's a slot down the right hand side of the battery compartment you need to feed this tube through. It routes alongside some other cables through a little metal hoop. You want the end of it pointing down below the bike. The battery has a little nipple on that side that the tube attaches to.
You can also get the battery from JPCycles for $25+shipping, but you will need to add the acid and water yourself, as well as do the initial charge.
Just call up the local bike shop.
If you don't have the service manual yet, get it:
eBay link
