Page 1 of 2
dont laugh
Posted: Sat Oct 14, 2006 5:56 pm
by srwhite_
hi i was wondering if there was a secret method of safely putting my gl 1100up on the center stand. if those japs can do it i should be able to but i have turned it over twice now
Posted: Sat Oct 14, 2006 6:11 pm
by Shiv
What do you mean? Just simply putting it up there or are you trying to do it while doing some kind of weird stunt or something?
Posted: Sat Oct 14, 2006 6:22 pm
by VermilionX
hehe... im not strong too. i dropped my when i tired to remove the rear stand on my own.
anyway... i have no experience w/ centerstands. i assume the GL 1100 is almost 600lbs. if you can't do it alone then ask for assitance.
i know i will never attempt to use the rear and front stands on my own again.
Posted: Sat Oct 14, 2006 6:24 pm
by kellanv
Yeah, I was nervous as hell about putting my bike on the centerstand the first time. The best way I've been able to do it is put the bike on the kickstand, get off the bike, go to the rear of the bike, push down the centerstand with your food till one leg touches ground then simultaneously push down a bit more while using your hand to straighten up the bike. You should now have the bike upright and both legs of the center stand firmly against the ground, holding the bike in said upright position. From here its just a matter of lifting a bit with your arm and pushing down with your foot to pop the sucker up on the stand...
Good luck. Its a little scary at first.
Posted: Sat Oct 14, 2006 6:49 pm
by Mintbread
When I use my centre stand, the best method I have found is to stand on the left of the bike and hold it upright with your left hand on the left bar and your right hand on the passenger footpeg hanger (or somewhere on the tail you can grip easily). Push down on the centre stand hard with your right foot and simultaneously pull the bike up and back.
Posted: Sat Oct 14, 2006 6:52 pm
by kellanv
yeah I do a little closser to what mintbread suggested. I forgot that I usually stabilize the bars with my left hand as well.
Posted: Sat Oct 14, 2006 9:39 pm
by TechTMW
I sold a 250lb weight lifer my Suzuki vx800 - He couldn't get it on the center stand either until he practiced a few times. Don't give up, it's all in the technique - just practice.
Oh, and have somebody spot you next time
Posted: Sat Oct 14, 2006 10:30 pm
by CajunBass
I had a hard time with my Yamaha Majesty and the center stand at first. I'm 300 lbs, and that thing would not budge. Then I found the trick to that bike anyway is to make sure that both feet of the center stand are planted firmly on the ground. After that, it just jumped on the stand.
Posted: Sun Oct 15, 2006 5:14 am
by Sev
Step on the stand with your right foot, and push the bike into a vertical position using the stand to assist you.
Then rather then pulling it back or to either side, lift straight up as hard as you can. The stand wants to spring into place and you lifting up will help it do so.
Posted: Sun Oct 15, 2006 9:11 am
by superskip
Dumb question here...
What is the center stand for ? Like out on a trip or around town when would u use it ? At home I plan to use a jack or auto engine hoist if I ever need to do maintenance - so far my center stand is just dead weight.
