Neutral Light always on
I have a '74 CB360 that is about 85% restored. I have a few nitpicky problems left and one is that the neutral light stays on all the time, no matter the gear. Has anyone else ever come across this problem?
- TechTMW
- Years Riding: 10
This is almost certainly a grounded wire on the neutral light circuit _before_ the neutral switch but _After_ the dash light. You need a good wiring diagram. (It could also be the switch itself - but the switch breaking isn't as common as a wiring failure)
