2000 Suzuki Marauder Clutch adjustment
Posted: Thu Oct 19, 2006 4:38 am
by mikesen
I have a 2000 Marauder i've only had the bike since august and ever since then when releasing the clutch it doesn't grab until i'm almost letting go of the lever. It's a cable and has adustments at both the lever and were it connects to the arm. is there a way to ajust it so it releases about half way. no matter how many times i adust it i can't get it to release in the middle it's always at the end. am i doing something wrong or is the clutch just wore. it's only got a bout 8k on the bike. any help would be apprieciated. thanks
Posted: Thu Oct 26, 2006 4:59 pm
by touge_dorifuto
I had the same problem on my '98. I adjusted it at the clutch lever.
Posted: Thu Oct 26, 2006 6:20 pm
by Shorts
You can fine tune at the lever end, but if you need big adjustment, go to the tranny end, then fine tune at the lever again.
