Honda NX 650 engine question
MTL
#1 Unread post by MTL »
Hello,
I recently aquired an 88 Honda NX 650. After removing the 2 caps on the left side case that are removed to allow for timing and hand cranking the flywheel I found that oil came out of the lower/larger hole. Is it normal for the flywheel and generator to be in oil? At first thought it seemed that this area on the engine should not be submerged in oil, but there are starting gears also in this area under the cover. Is oil in this area normal?
Thanks, Matt
