winner of stupid question award
Posted: Sat Nov 11, 2006 12:44 pm
by Andrew0853
ok i'm this may be incredibly stupid but are all motorcycles manual; and if not how do u tell?
P.S is the 2002 Honda : VTR 1000 F Super Hawk a good starting bike and/or good bike alltogether and is 2k a good price for one?
Posted: Sat Nov 11, 2006 12:50 pm
by Shorts
Pretty much all motorcycles are a manual tranny (with the exception of a few or smaller cc dirtbikes), that means you need a clutch to shift gears. To see if a bike is a manual, look on the left handle bar for a lever. Now trace the cable/hose that goes from the lever, it should go into the top of the engine/clutch cover. Then you know that is a manual. If you oull tht lever on a cable actuated clutch, you can see the little connection move on top of the cover.
Or, if you're looking at a spec sheet for a motorcycle, it will be described as:
clutch - wet or dry
transmission - 5/6 gear (or speed) then list the ratios
Posted: Sat Nov 11, 2006 12:57 pm
by Sev
Yeah, I can only think of a handful of bikes that aren't manuals. And they're sorta custom jobbies. Chances are really good that if it's a Big 4, Duc, or BWM it'll be manual.
Posted: Sat Nov 11, 2006 12:59 pm
by Andrew0853
thansk just what i needed
Re: winner of stupid question award
Posted: Sat Nov 11, 2006 5:54 pm
by VermilionX
http://www.motorbikes.be/en/Honda_VTR_1 ... _2002.aspx
people here recommend to stay within 50 bhp or less for a 1st bike.
so nope, the VTR 1000 won't be good choice since eventhough it's not as powerful as today's 600cc supersports... it's still up there in the less-forgiving territory.
Posted: Sun Nov 12, 2006 6:03 am
by Wrider
Shorts wrote:Pretty much all motorcycles are a manual tranny (with the exception of a few or smaller cc dirtbikes), that means you need a clutch to shift gears. To see if a bike is a manual, look on the left handle bar for a lever. Now trace the cable/hose that goes from the lever, it should go into the top of the engine/clutch cover. Then you know that is a manual. If you oull tht lever on a cable actuated clutch, you can see the little connection move on top of the cover.
clutch - wet or dry
Listen to this lady, she knows what she's talking about! Also, if you're looking for a nonmanual, look at Ridleys, those use a CVT transmission. They have no specific gear, just a belt drive that's diameter changes to increase speed from the same RPMs...
Posted: Sun Nov 12, 2006 7:14 am
by qwerty
Actually, the belt's diameter doesn't change, the pully(ies) diameter(s) change(s).
Posted: Sun Nov 12, 2006 9:10 am
by Sev
qwerty wrote:Actually, the belt's diameter doesn't change, the pully(ies) diameter(s) change(s).
Yup
Centrifical force either pulls the plates of the pully apart or closer together depending on if it's a front or rear. This causes the belt to ride up or down and simulates changing gear ratios.
Posted: Mon Nov 13, 2006 10:23 am
by WyoSemRider
Andrew0853 wrote:ok i'm this may be incredibly stupid but are all motorcycles manual; and if not how do u tell?
Click onto
www.ridleymotorcycle.com to see a fully-automatic American-made very nice motorcycle.
