Opinions wanted
Posted: Sun Dec 10, 2006 3:30 am
I have a 1985 Hondel Rebel 250. It's in great shape and even though I have decided to move to a larger bike in the Spring, I want to hang onto this bike. I'm hoping that there will be a Mrs Slowair someday.
Anyway, I have a problem. I want to keep the bike original. So far everything is stock and works fine.
However, as I was enjoying one of the last days of the season, something very odd happened. One of the studs holding the exhaust flange sheered off about an eigth of an inch inside the hole. I sounded like an old WWI biplane going down the Interstate.
My brother (the mechanic) told me to try using an EZ Out. Went to NAPA, got advice, a drill bit and the EZ Out. First, the tip of the drill bit broke off inside the hole. I was pretty sure I had gone far enough in that the tip would not prevent me from using the EZ Out. On the second tap of the EZ Out, it broke off inside the hole.
Now I've got two pieces of tool hardened steel inside the hole.
So brother comes out, grabs a drill and a bit and starts trying to drill through the mess. I not the mechanic, but even I knew he wasn't going to drill through that mess. It would be like cutting butter with butter. After breaking three bits, he ended up drilling a hole all right...right along side the other one. Not good!
So here's where I need opinions.
I want to keep this bike and I want to keep it original.
He wants to take it and either drill out the hole and put in a larger stud, or weld the nut and exhaust flange onto the old bolt . Either way, it's gonna be ugly and not very orinial.
The only other thing I can think of is to replace the cylinder head. Honda wants $367 for one. I got the bike last year for a grand. And I have no idea what else is involved in replacing the cylinder head.
Can I put in a used one?
How much work is involved in the project?
Will I need to get other parts as well, besides the new stud?
Or should I just forget about it and start selling used parts on eBay?
Thanks for taking the time to read all this and for any advice you can offer.
