Ignition Troubles
Patient
Ignition Troubles
#1 Unread post by Patient »
So i've got about 600 miles on my bike now, i'm just about to take it in for it's first service (Still a newb, and i want it checked by a pro for it's first tune-up) But i want to have all the info i can when i take it in, hence my inquiry.
Since I've had the bike It's had trouble starting up about 4 times. I go to start the bike, make sure it's in Neutral, Hold the Clutch, Press the ignition... The engine starts to turn over, but never catches. The first a couple of times it just took a few tries then worked fine. But today at lunch it wouldn't start. I tried about 4 times with no luck before i gave it a little gas to help it turn over. This method worked,..but left me feeling like something is wrong. My rommate has a CBR 600RR and i've never heard his bike struggle to start.
A few more details.
- 07 Suzuki GSX-R 600
- I've only noticed the problem during the day, after it has sat outside in the sun for at least 10 minutes
- I do not use the emergency shut off when i park for the night, Only when i know i wont be riding for a few days.
- I do start my bike while it is on it's kickstand (in neutral obviously) to warm it up while i put my gear on.
Is it my technique? or could it be a bigger problem?
Again i'm taking it in to be serviced this weekend, but would like to know if i "shouldn't" be riding til then... for some reason.
Thanks all.
07 GSX-R 600
#2 Unread post by Sev »
Sounds like a low battery. Check the voltage with a volt meter... if it's below 12 volts throw it on a trickle charger and see if this will recondition it.
Patient
#3 Unread post by Patient »
A low battery on a brand new bike?...with less than 600 miles.
Well, i guess thats an easy solution if thats the problem, but geez...that doesn't sound right. : \
07 GSX-R 600
2will
#4 Unread post by 2will »
newb on a gixxer 600? cool! :ohyea:
2will
#5 Unread post by 2will »
haha. "patient" an appropriate username. just noticed that. :laughing:
Shorts
#6 Unread post by Shorts »
Patient wrote:A low battery on a brand new bike?...with less than 600 miles.
The solution is to buy a battery tender to keep the battery up to par. Bike batteries don't like to sit very long at all.
That like when you go to a car dealership in the winter and brand new cars and trucks don't want to start for a test drive because the batteries are weak and cold from not being used...in the cold!
It doesn't matter how old or new the bike/car is, what matters is the battery/power source.
Patient
#7 Unread post by Patient »
Thanks for the info, i'll definetly give that a shot.
I'll let you guys know how it works out.
On another note,
"2will"... You dont need to patronize me. Please add to the conversation, or be on your way.
07 GSX-R 600
#8 Unread post by Sev »
Two things are possible if it's a low battery:
1) You accidently left the ignition on and drained it.
2) The battery was not given the correct charge when the bike was first PDI'ed.
You can pick up a multi meter for as little as $20 Canadian, you can use it to check the voltage of your battery. A voltmeter only would probably be cheaper... so I'd start there before buying a battery tender.
Patient
#9 Unread post by Patient »
Sevulturus wrote:Two things are possible if it's a low battery:
What is "PDI'ed" ?
07 GSX-R 600
#10 Unread post by Sev »
Taken out of the crate and assembled/checked for you.
