Possible future project. Need electronics 101 course help.
Posted: Mon Feb 19, 2007 11:30 am
There is an article over on whybike.com that states how to add a cigarette lighter to your bike so you can make use of your battery. I'm thinking of getting into the whole helmet cam bit and I'd like to just tap off the battery.
http://www.whybike.com/blog/index.php?m=20060429
That is the article. Now, I have a question that wasn't cleared up in that article and he has his comments blocked so I'm hoping there are some electrical gurus here.
This is what I want to accomplish and forgive me if I sound like a novice when it comes to electrical material, because I am.
1) Buy a generic cigarette lighter socket.
2) Get the neccessary wire for it to run it along the length of my bike.
3) Have a fuse attached so I don't fry whatever I have plugged into it.
4) Attach it directly to the battery as I doubt I have an accessory line like other bikes do.
I can gather how to wire the wires up. However, how do you regulate how much the battery outputs or does the device that is connected draw out the power instead of being "force fed" more than it can handle by the battery? I know that if the voltage goes higher than the amp rating on a fuse, it'll blow the fuse. I'm needing this for something that would take about 5volts from the battery to keep a device charged while the bike is in motion. I know there is 5a and 10a fuses, do they make a 6? How does a generic fuse connect to the wiring?
This will be my electronics 101 course.
To whomever responds, thanks very much.
