Page 1 of 2
Stuck my neck out!
Posted: Wed Apr 11, 2007 4:32 pm
by Moses
Yesterday i bought a 1999 Kawasaki Ninja 250CC 13,200 miles clean as heck. Got the work shop manuals, helmet , bike cover, tank saddle bag, Spider web bungie. Great the engine wont run!! The previous owner said it just quit, And will not turn over,at the end of last season this spring he took a try at starting again nouck got a new battery still no good. When i looked at it I hit starter nothing! The PO has no mechanical skills his grand dad helped him put the new battery in. He called a shop and they quoted ther labor rate and that scared him so he decided to sell it !! I got all the extra stuff and the bike very clean Kaw green. For $550.00 Now lets get this baby fired up and running! where to start frist Guys? What do you think Ideas Suggestions welcome. Thanks
Posted: Wed Apr 11, 2007 4:36 pm
by jonnythan
Do the lights come on or is the electrical completely dead?
No run ninja
Posted: Wed Apr 11, 2007 6:07 pm
by Moses
adont know yet will hopefully be getting it Sat april 14th thats when the fun begins Ha ha LOL I will check your suggestion as soon as i get it. thanks
Posted: Wed Apr 11, 2007 7:02 pm
by Gadjet
first things first:
Before you look at anything else on the bike to try to solve the problem, check to make sure all the fuses are good. It could be something as simple as a blown fuse, in which case you got yourself a hell of a deal.
If all the fuses are good, check to make sure all the ground wires have a good clean connection.
Thanks Guys
Posted: Thu Apr 12, 2007 3:56 am
by Moses
Joohnnythan & Gadjet thanks for the input Good ideas, Im hoping its some thing simple! "Please Lord" But i couldnt Pass on this deal!!!
1999 kawsaki 250 ninja
Posted: Sun Apr 15, 2007 4:44 pm
by Moses
I brought the bike home sat. and started on it right away Ist checked all fuses cleaned battery terminal connections lucky for me i got the Kawsali factory repair manuals with it. so I do have lights but now sure if I have enough juice to kick in the starter I may try to jump it tomorrow and see what that does. So far very happy is in great shape for A 1999 13, 200 miles now if i can just get it to start. I may take the starter off and see what its doing If you have any Ideas please lets hear themmm thanks Moses
by Moses
Posted: Mon Apr 16, 2007 1:50 am
by Johnj
When you press the starter button, does the engine turn over but not start?
Or does the bike go click click click click click click?
Or does it make one click?
Stuck out my neck
Posted: Mon Apr 16, 2007 5:47 pm
by Moses
Well i got it up on the center stand I tryed to turn the rear wheel. fine in neural but when placed in gear No movement other than chain flex, Will not even bump with eletric start, will pull the plugs tomorrow, Im gettin a bad feeling Previous owner said it just Quit! Where can you get a rebuild kit and gaskets ? Any one who has re
built a 250 kaw Let me know how it went and whats the best route to take. Thanks Moses
Posted: Tue Apr 17, 2007 12:45 am
by storysunfolding
SO the starter doesn't do anything? If so, make sure it's getting current. If not- try to source one on ebay.
If the starts does work and the engine just isn't firing check these:
put it in 6th gear and see if you can turn teh wheel then. Very hard to turn by hand in first.
IF that works, get a compression gauge and check compression, compare to factory manual
If that's ok check spark
If that's fine, clean the carbs and change your fuel out. This is the most likely culprit in my mind for a bike that was put away running and came out of storage not running- so maybe start here.
