Clutch Slipping
Posted: Tue Apr 24, 2007 9:53 am
Hello,
I have a 1982 HOnda CB 650 SC with 33K on it. I am having troubles with the clutch slipping under load. I adjusted according to the manual, and there is almost nothing to the clutch, the lever is just limp, even when I move the cable out as far as it goes. However when if I mess around with the adjustment of the clutch iteself I can get it so that the clutch lever has the feel that a clutch should, but then I get the slipping. I just pulled the clutch springs off today and they where inside there tolerances, I have not yet looked at the plates. So my question is do I need new springs and plates or is my cable just very stretched?
Thanks,
Nate
Thanks,
Nate
