I will be removing the small plugs over the air mixture screw on my Vulcan 750, and would like to know the best way to get those little buggers off? I've heard that some riders use a drill, but I would rather
use something else if possible?
Removing plugs over air mixture screw.
- norsseman
- Location: In the Country. Far back in the deep dark woods. Geiger Heights, Washington
Freedom is not Free
- Johnj
- Real Name: Johnny Strabler
I guess you could try a small drift or punch and a hammer, but I think the best method is to drill a small hole and start a screw into it. Now grab the screw with your pliers and give it a tug.
- Damian
- Years Riding: 5
- My Motorcycle: 1994/Honda/Magna
Yeah, that's the best technique I've found. Just be sure not to drill too deep, you only need to get through the cap. The screws below are usually pretty soft, if you bump them with the drill, you might damage them.Johnj wrote:I guess you could try a small drift or punch and a hammer, but I think the best method is to drill a small hole and start a screw into it. Now grab the screw with your pliers and give it a tug.
1994 Suzuki Katana 600
1994 Honda Magna 750
