how do i take-off/bypass the smog canister?
Dirtytoes
#1 Unread post by Dirtytoes »
i'm trying to take off the smog canister because it scrapes alot...
FYI, only cali models have this canister.
so assuming that i got the numbering right...
connect #7 to the left side of the censor? (replace it with #8 ) and just take everything else off?
...so the fuel vapor from the gas tank will to directly to the censor (without going the can) and the censor will forward it to the throttle body?
am i missing something, or will this work? ...i just wanna be sure before i actually do it.
PS....wat does the "EVAP PURGE SONLENOID VALVE" do? someone told me NOT to take that off.
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
#2 Unread post by Sev »
GARAGE FORUMS!
Dirtytoes
#3 Unread post by Dirtytoes »
:frusty: :frusty: :frusty:
Bikes:
Gadjet
Real Name: Owen Clark
Years Riding: 19
#4 Unread post by Gadjet »
Shuffled over to the appropriate discussion area
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
mydlyfkryzis
Years Riding: 42
#5 Unread post by mydlyfkryzis »
You are playing with fire....literally. The Tank vents into the cannister. The cannister has activated charcoal that absorbs the gas fumes. The purge valve opens only under certain conditions and draws the collected vapors out of the cannister and charcoal. If you leave the hose open to atmosphere, you may have explosive vapors collect around the bike.
There is no performance loss with this system.
If the cannister is scraping, you might do better to find a place where the cannister doesn't scrape and just use longer hoses.
If you connect the vent line (#7) directly to the purge valve, your tank will be un-vented when the purge valve is closed. When the valve opens, engine vacuum will probably collapse the fuel tank.
Richard - Fully Dressed
Naked 1976 Honda CB360T
Dirtytoes
#6 Unread post by Dirtytoes »
mydlyfkryzis wrote:You are playing with fire....literally. The Tank vents into the cannister. The cannister has activated charcoal that absorbs the gas fumes. The purge valve opens only under certain conditions and draws the collected vapors out of the cannister and charcoal. If you leave the hose open to atmosphere, you may have explosive vapors collect around the bike.
thx for ur input.
good thing started this thread be4 actually attempting to connect #7 to the purge valve :roll:
is there a right way to remove the can?
p.s. this other guy once told me to "hose one pipe to the other and cap off the other one"....i forget exactly wat he said....does that make any sense to u?
Bikes:
Dirtytoes
#7 Unread post by Dirtytoes »
wat about something like this?
Bikes:
mydlyfkryzis
Years Riding: 42
#8 Unread post by mydlyfkryzis »
That may work. You need an airfilter at the end of the "new" tube. When the purge valve opens, it pulls in air into the engine.
You may has a gas fume issue especially when the bike is parked. Normally, the cannister absorbs the fumes.
If you don't break anything, you can always restore it to stock.
Where is the cannister mounted that it scrapes the ground?
Dirtytoes
#9 Unread post by Dirtytoes »
mydlyfkryzis wrote:That may work. You need an airfilter at the end of the "new" tube. When the purge valve opens, it pulls in air into the engine.
by "new", are u referring to he one that says "fresh air" ?
and its located at the bottom of the bike, around where the headers connects to the muffler...its about 2-3 inches lower than the headers.
Bikes:
Dirtytoes
yes!
#10 Unread post by Dirtytoes »
finished it earlier today....can't really feel any power difference but i hav ALOT more ground clearance now! :mrgreen:
Bikes:
