Triumph Trophy- Next Installment
Posted: Thu May 12, 2005 4:30 pm
Well took the misbehaving Trophy to the dealer today to have it checked out. I set it up for a quick diagnostic seeing as how I had to ride the bike home afterward so we couldn't get into dismantling it.
The bike ran great on the freeway all the way to the exit. It stalled at the exit light and then again when I pulled into the parking lot a couple minutes later. We've had a couple of 85-90 degree afternoons the last couple of days and the bike runs really well when it's super hot out.
This mechanic that I'd spoken to on the phone discussed what I'd been going through and then he took it on a test ride. Said that he'd seen another bike similar to this and it ended up being the ECU, although he kind of grimaced at that ($$$$) and he said that the problem sounded unusual.
He took it in the back and ran an Exhaust Gas Analyzer test. Hydrocarbons looked pretty good with one side a little high, probably due to the jerry-rigged carburetor cap repair that we made (have the panew part, haven't gotten it on yet). The idle mix screws were still capped. He was quite impressed with how well the carbs seemed to be dialed in when it was running (thanks to my friend's handywork).
Bottom line, it isn't carburetion. He thinks it's either the coil pickup (simple repair) or the ECU (about $1000)
He suspects the worst. He mentioned the EPA warranty and that he might be able to get it done under that warranty but it would take a couple days since there's a bunch of testing that has to go on with UK engineers on the phone (6 hour time difference) and with the engine cold and then hot, etc. Then he sent me home to think about it, and didn't charge me a dime for the heads up (Jerry at Fredericktown Yamaha/Triumph in Frederick, MD. Can't say enough good things about the guy).
Being an engine engineer, I'm plenty familiar with EPA warranties so I looked it up in the owner's manual. Basically, the emissions warranty is 5 years/18,632 miles. Looked up my records. The bike was purchased 5-13-00
and only has 13,000 miles on it. Wooo wooo! The ECU is a standard emission component (doesn't say that in the manual, but I know it to be true).
So I'll be arranging to take it in for the full exercise. If it's just a pickup, they'll do a cheap repair. If it's the ECU, it's under warranty. Thank heaven I didn't wait until Monday!
Sorry that EPA warranties don't help you parsley1938, but at least you know some kind of direction.
Onward and upward.
Onward and upward.
