Help Cant Pass Inspection something wrong with Brake Light
Posted: Tue May 22, 2007 7:55 am
by psbardella2000
Can someone please help me I am having a problem where on my 1981 Yamaha XS800. The brake lights stay lit and will not go out so i cant pass inspectons till i get them going agan they were working know they just stay on can any help me with this so i can fix it and get it on the road
Posted: Tue May 22, 2007 12:22 pm
by Gadjet
First, check to make sure that your brake light switches (both back brake and front brake) are properly adjusted and clean.
Posted: Tue May 22, 2007 2:05 pm
by flynrider
What Gadjet said. The most common cause of your problem is either a dirty switch, or poorly adjusted switch.
I'm curious to know what an XS800 is. I've ridden XS750s and 850s (inline triple), but didn't know there was an 800.
Posted: Tue May 22, 2007 2:40 pm
by psbardella2000
Where are the brakelite switches on this bike it is a xs850 not 800
Posted: Tue May 22, 2007 2:47 pm
by Sev
I would guess that there is one in the handbrake, and one near the footbrake.
brake lite
Posted: Tue Jun 05, 2007 2:58 pm
by slimcolo
It may be dirty brake fluid if your bike has hydro-activated switch (these may be anywhere in the brake line), a common problem with Juice brakes that came out in 58 on el and fl This is especially true if someone has added a lower quality fluid. IE dot 3 or 4 in a dot 5 system Also look for contaminates esp. water. Many states have a must work if present clause about front brakes/lites. If its removed its not there and legal. Ck your state laws and this is for front only.
