C50 Running Hot..
Boojak79
C50 Running Hot..
#1 Unread post by Boojak79 »
Hello,
I just installed some Vance and Hines Cruzers on my 06 C50. Now, after about 20min of highway riding in about 70 degree weather my temp light comes on.
A) I'm thinking it could either be getting hot due to not installing a fuel management system with the new pipes and running a bit lean.
B) When installing the rear pipe I had to remove the coolant hose from the head. Maybe I got an air bubble in the cooling system???
C) I some how blew the fuse to my fan. I noticed while sitting at an red light after the temp light come on that my fan wasn't running. I know it was hot enough to kick on being as my light had been on for about 3 minutes. However I can't find the fuse to the fan in the fuse box.
A couple things of note.
When I shut the bike off and got to looking I could smell coolant but could not see any over flow or leaks anywhere. Also, the over flow tank is full and cool to the touch after even with the motor running hot.
By know means am I an expert on the matter, so I apologize in advance for the lack of info but I would be very thankful to any input you may have.
__________________
06' Suzuki C50
#2 Unread post by BuzZz »
It might be running lean from the new pipes, but the other symptoms make me think the cooling system is air-locked or just low on coolant.
If it is air-locked, the coolant will be just splashing around in the pump or around the engine, not through the rad.... where the temp sensor for your fan probably is.... but the high heat light sensor is probably in the waterjacket on the motor.
You need to try bleeding the cooling system as thoroughly as possible and adding coolant as necessary through the rad cap.
