Page 1 of 2
1996 cbr 600 making grinding noise
Posted: Sat May 26, 2007 6:18 am
by tank99_999
its makeing grinding noise from the igniton cover and i dont know what it is :cry:
Posted: Sat May 26, 2007 12:45 pm
by Sev
What do you mean by ignition cover? I'm not familiar with that term :(. Is it a grind or a rattle? Does it increase with rpms or dissappear at certain rpms? Does it sound like something is shaking around in there? Or just like something is clacking.
As a guess I'd say your camchain tensioner might have given up the fight, but it could literally be anything in there...
Do you stunt? Have you crashed recently? When did the sound first start? What happened right before that?
Posted: Sat May 26, 2007 6:11 pm
by BuzZz
They didn't teach you what an ignition cover is up in Fairview, Sev? Time to start calling the school and complaining. Loudly. :wink:
Here's one on an R-1....
http://www.superstreetbike.com/custombi ... o_05.html#
As for the grinding noise..... could be the flywheel nut has backed off, or a hunka crud as slipped in past the vent and is banging around in there, or something busted off and is doing the same.
Really, taking that cover off is pretty easy. Yank that thing and take a peek. That will tell you more than any answer you'll get asking someone.
Posted: Sat May 26, 2007 6:18 pm
by Sev
Isn't that the stator/alternator cover :P?
Posted: Sat May 26, 2007 6:38 pm
by BuzZz
a.k.a..... ignition cover.....
Posted: Sun May 27, 2007 4:14 am
by Sev
Something new every day!
Like BuzZz said, haul it off and look inside, try to be a little careful pulling it off, as if you rip the gasket you'll leak oil until you replace it.
And when you tighten it back on, do so in a cross pattern.
Posted: Sun May 27, 2007 6:37 am
by wickedrider
Thanks gentlemen. Now I too know what an ignition cover, i.e. stator alternator cover is.
Posted: Thu May 31, 2007 10:02 am
by tank99_999
i took it off and there is nothing in there and it only dose it when its cold ?? after i start it up then when it runs for a bit it stops? thanks for the help
Posted: Thu May 31, 2007 4:57 pm
by BuzZz
Are you sure the noise is coming from the ignition cover? Did you start the bike with the cover removed?
Is it maybe coming from higher up on the engine, like from the valves?
Or from back in the tranny/clutch area?
Posted: Fri Jun 01, 2007 8:14 am
by tank99_999
it wont start with it off idk i think im going to take it in thanks for the help :D :lol:
