Page 1 of 2
Honda Shadow VLX 600 Clutch Problem?
Posted: Sat Jul 07, 2007 2:20 pm
by dvmahanson
When I engage the clutch and shift into gear from neutral, the engine dies. Engine runs good and I've tried adjusting the clutch cable at the lever the full range of adjustment and can't seem to solve the problem. Any ideas?
Posted: Sat Jul 07, 2007 2:39 pm
by telefunkin
are you giving it gas as you let the clutch out?
Posted: Sat Jul 07, 2007 7:45 pm
by blair
Is it stalling like it's engaging the gear or is it just quitting like you hit the kill switch?
Posted: Sat Jul 07, 2007 9:40 pm
by Sev
Kickstand/kickstand switch.
Posted: Sat Jul 07, 2007 9:41 pm
by Sev
Posted: Sun Jul 08, 2007 1:10 am
by dvmahanson
It dies the instant I kick it into 1st gear while the clutch is still engaged. I would say it is like the fuel switch turns off because no matter how you manage the throttle, it dies. If I try to increase the rpm's while I shift, the gear's grind and it doesn't want to shift into 1st.
Posted: Sun Jul 08, 2007 5:34 am
by Sev
Seriously, check the kickstand/sidestand kill switch. Is the kickstand down?? Or is the switch sticking?
That's considered a safety feature.
Posted: Sun Jul 08, 2007 10:42 am
by dvmahanson
Sev, you're the champ. Thanks so much. I had no idea such a switch existed. It worked. Kickstand down, engine dies. Kickstand up, no problem. Thanks again.
Posted: Sun Jul 08, 2007 4:10 pm
by flw
I'm trying to understand what you did so you shifted into first while you had the kickstand down?
Posted: Mon Jul 09, 2007 2:40 am
by Sev
Whew, that's good at least. Sometimes the switches stick or break so that the bike does when you go into gear no matter what. That's a bit tougher to diagnose by yourself.
