Throttle doesnt roll back on its own
Posted: Sat Jul 07, 2007 6:11 pm
by Morph
Hey my throttle wont roll back on its own (like if i roll it fully open it'll stay there and wont move back) and I'm wondering whats up with it... anyone got any ideas?
My bikes a CBR600 btw
Posted: Sat Jul 07, 2007 9:42 pm
by Sev
Check to see if your bar ends are binding against the grip.
Check the cables for proper routing, make sure the return hasn't snapped.
Don't ride the bike like that, it's considered to be basically really unsafe.
throttle
Posted: Sun Jul 08, 2007 1:53 am
by Gnarlyroad
When was the last time you lubed the throttle cables. Try doing so before you ride again. Stuck throttle totally unsafe.
Posted: Sun Jul 08, 2007 4:45 am
by slimcolo
You may have a wire (internal, used mostly on earlier American bikes, Cushman,Indian,HD, but still used on customs) not cable operated throttle. In this case its just fine. Federal government regs. mandated snap back throttles at same time as wrong shifting. (1975) You know we had to follow the Japs and Germans rather than Brits, because they treated us so good in the past!
If you have cable check for fraying at both ends. Make sure throttle stop (if you have) Isn't sticking. Make sure cable isn't binding. Take apart throttle and clean and relube. (it may need replaced if badly worn) Most common cause is just grit. Also hit your linkage on carb with carb cleaner. Also check and make sure housing isn't pinched somewhere like in the fork stop.
Posted: Sun Jul 08, 2007 5:22 pm
by Morph
Hmm it might be the throttle cable.. im gonna try to ride it to a local dealership and get it checked (i dont feel comfortable messing with the inside things yet)
cable
Posted: Tue Jul 17, 2007 4:21 pm
by tcreeley
On my bike the throttle cable jumps back because of the spring in the carb. check the linkage for smoothness all the way back to the carbs. Look for any rough sliding as you twist it- usually something simple- unless plastic is involved- that wears.
tcreeley
Posted: Fri Jul 20, 2007 7:32 am
by Philthy McNasty
What Sev sez. & check cables-lube them, & Some bikes have two cables, 1 for giving gas, one to return. But what do I know?
