Throttle doesnt roll back on its own
Morph
#1 Unread post by Morph »
Hey my throttle wont roll back on its own (like if i roll it fully open it'll stay there and wont move back) and I'm wondering whats up with it... anyone got any ideas?
My bikes a CBR600 btw
#2 Unread post by Sev »
Check to see if your bar ends are binding against the grip.
Check the cables for proper routing, make sure the return hasn't snapped.
Don't ride the bike like that, it's considered to be basically really unsafe.
Gnarlyroad
throttle
#3 Unread post by Gnarlyroad »
When was the last time you lubed the throttle cables. Try doing so before you ride again. Stuck throttle totally unsafe.
slimcolo
#4 Unread post by slimcolo »
You may have a wire (internal, used mostly on earlier American bikes, Cushman,Indian,HD, but still used on customs) not cable operated throttle. In this case its just fine. Federal government regs. mandated snap back throttles at same time as wrong shifting. (1975) You know we had to follow the Japs and Germans rather than Brits, because they treated us so good in the past!
If you have cable check for fraying at both ends. Make sure throttle stop (if you have) Isn't sticking. Make sure cable isn't binding. Take apart throttle and clean and relube. (it may need replaced if badly worn) Most common cause is just grit. Also hit your linkage on carb with carb cleaner. Also check and make sure housing isn't pinched somewhere like in the fork stop.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
Morph
#5 Unread post by Morph »
Hmm it might be the throttle cable.. im gonna try to ride it to a local dealership and get it checked (i dont feel comfortable messing with the inside things yet)
tcreeley
cable
#6 Unread post by tcreeley »
On my bike the throttle cable jumps back because of the spring in the carb. check the linkage for smoothness all the way back to the carbs. Look for any rough sliding as you twist it- usually something simple- unless plastic is involved- that wears.
tcreeley
Philthy McNasty
#7 Unread post by Philthy McNasty »
What Sev sez. & check cables-lube them, & Some bikes have two cables, 1 for giving gas, one to return. But what do I know? :laughing:
Sunshine & 80 degrees!
