Engine problem
Posted: Mon Jul 16, 2007 5:16 pm
by TRunner
Hello all, I'm new to the forum and have spent some time peruzing topics related to my problem. The forum seemed very helpful and so I have decided to join and learn from your expertise.
I have a 1985 Honda XL600R. It has dual carbs and the fuel valve is on-off-res. (with no vacuum assist). I bought this bike 2 mo. ago. When purchased I was told it wasn't running very good, and leaked some oil around the head/valve cover, but the top end had been rebuilt. I tore the engine apart to find a beautiful cylinder and piston. The valves seemed to seat well and everything seemed good. However the timing chain was off one tooth. I fixed that and cleaned and adjusted the carbs to specs. Once back together I found that a new battery was needed and after that it ran great. I took it out on some trails and it performed strong all weekend. I rode it to work for about a week when the following problem begain to manifest itself:
It ran good for a while and then would die at idle. It progressed to a slight sputter when cruising, and then got worse. This morning I took it to work (or attempted at least) for the first time in 3-4 weeks. about a mile away from the house it began sputtering and losing power really bad so I hit a neighborhood road to avoid traffic. With every sputter came light blueish exhaust. It got worse rapidly and then died. I tried kick starting it for about 30 min (it had even cooled down) to no avail. I noticed some liquid coming out of the air filter box (on the left side of the first pic) It looked a little oily and had the scent of gas! I then pushed it home 1.5 mi. (good thing it's not a full on street bike!!!) Tonight I pulled the filter out and the bottom portion was drenched in gas. The small black canister in the first pic (on the left side, just under carb #1) has a drain with a plug at the bottom (shown under the letter K on the suspension linkage, in pic 2). I unplugged it and the same gaseous liquid came pouring out. I was amazed at how much came out. It was then that I noticed that the canister had a line going to the bottom of the air filter box. (What exactly is this canister any how???) after that It started with 2 kicks. I rode it for about 8-9 min and it began to have the same symptoms, I eased it home and it died while idling to my parking spot.
I have tried taking the gas cap off while riding, and the gas valve (I'm not sure the technical name mentioned in other posts) is letting plenty of gas out. Spark plug is new, Did the test on the electrical components except the Capacitor Discharge Ignition unit, which has no way to be tested, when I first got it and had what turned out to be a bad battery, and everything was in specs. It also has a new spark plug. Any ideas??? Sorry about the long thread but I'd rather give more info than not enough... Thanks in advance!!!
Oops, just realized I can't upload the pics, I don't have a URL available. sorry :(
Tyler
1985 Honda XL600R
Posted: Mon Jul 16, 2007 5:34 pm
by blues2cruise
You can get a photo account at image shack or pics place or photo bucket or flickr or picassa......create an account for yourself and then you can upload a pic.
Oh, and welcome to TMW. :)
Posted: Mon Jul 16, 2007 5:44 pm
by BuzZz
Check your oil. Good chance it's overfull and smells like gasoline. I'm gonna guess your float needle leaked a bunch of fuel into your crankcase when the petcock was left in 'on' overnight or longer.
If such is the case, you have to drain the oil, change/clean the filter and re-fill with fresh oil. You can run it for a few miles and do another quick oil swap as a flush if you want as well.
You will have to be sure to turn the fuel petcock to 'off' when you park the bike for any length of time until you change the float needle "O Ring".
If the oil isn't overfull and gassy, then the problem is someplace else....
Posted: Tue Jul 17, 2007 3:26 am
by TRunner
Thanks, I will check that asap. Hopefully It is the gas in the crank. I'll return with the findings!
Tyler
1985 Honda XL600R
Posted: Tue Jul 17, 2007 5:03 am
by storysunfolding
BuzZz wrote:Check your oil. Good chance it's overfull and smells like gasoline. I'm gonna guess your float needle leaked a bunch of fuel into your crankcase when the petcock was left in 'on' overnight or longer.
+1 that would have been my guess. I'd also pull the line from the fuel valve to the carbs, and see if it leaks at all on off. Rubber seems to disintegrate after 20 years. If this is the case pick up a petcock rebuild kit as well as a carb rebuild kit (if you're opening it up, why not?)
Posted: Wed Jul 18, 2007 12:52 pm
by TRunner
That was the best online diagnosis I have ever seen! The gasy oil came pouring out, and with some new oil she started with a half hearted kick. I rode her for about 15 min. and she was purring like a kitten. now all I have to do is tear into the carb. The petcock is in the off position for now... Thanks a bunch guys!!!
Tyler
1985 XL600R
