Shifting from first to second
Posted: Tue May 17, 2005 2:22 pm
When shifting from first to second at 5-6K RPM (or higher), there is a definite kunk/bang as the gear changes on my 82 Yamaha Maxim 650. At lower RPM, the shift is smooth with no problem.
Is this something that needs to be looked at immediately, or will shifting at less than the RPM that causes the problem enough of a solution? I am assuming this will be an expensive repair on an OLD bike.
Thanks!
Thanks!
