Yoshimura full or already full.
dio
#1 Unread post by dio »
I come from a place named..... Greece. Here to buy a Yoshimura full exhaust system for GSX-R k6 1000 you need 1750 Euro. To buy it from U.S.A. and get it from post office with full guarantine of product and travel safety and the shipment you need 951 Euro.?!?!?! Impossible? No check it and you won't believe it.
Now I have a question about something. Will I see difference in performance if i change full exhaust. Because the stock pipes are titanium, and the aftermarket pipes are titanium as well. Only the canister is from carbon. Does it worth the cost to buy something you already have or is it really different?
Shorts
#2 Unread post by Shorts »
Aside from weight savings, the benefit of a full exhaust system will come from the diameter of the tubing from the headers all the way out the muffler. A technically well built exhaust system will scavenge the exhaust gases at best efficiency and performance.
