Ugh, I don't even know where to start. I have a 1981 suzuki gn400. My bike seems to idle fine, and I can rev it up to higher rpms no problem while not moving, but it becomes a different story when I am moving. It seems to be able to get to somewhat higher rpms (5500-5700 approximately) in 1st gear, then I will shift up to 2nd gear, and my rpms will hardly drop down (probably from revving the bike up so high in 1st, I'm no mechanic though, and new to manual transmission, so if this is a possible problem, let me know
Once I get into 4th gear, my acceleration will begin to slow, and I can get, roughly, my rpms up to about 5000, and then when I shift into 5th, acceleration basically stops. I have my throttle opened all the way, I try shutting my throttle and re-opening. Still, it barely accelerates, and I can get up to about 47-MAYBE 50 mph and my tach will be at about 3500-3700.
My bike had some electrical problems, and my carb was a bit busted up, and I had a mechanic go over both of those, so I sure would hope that neither of these things would be a problem.
If any one has any other ideas or tests I could run to try to discover the problem, or if I need to give more information, I would completely appreciate it if you would respond. Thanks and good riding!
